Phantom problem on 94 camry! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2010, 03:31 AM   #1 (permalink)
View mrbishi's Photo Gallery
Australia Phantom problem on 94 camry!
Right i've had a look around to see if i could find the same probem but my eyes are gone fuzzy now.
I need some help with this issue now please. The problem is overheating. Now i've changed the rad, rad cap, water pump, timing belt, temp gauge sender, thermo switch sender, thermostat x2, all hoses.
so right the car will sit pretty at bang on half way on the temp gauge for hours. the fans dont need to kick in here coz the thermostat seems to be open when it idels like this. BUT, when i drive off the cool air cools down the water in the rad which closes the thermostat again causing the engine to get hot.
the head is NOT gone. now i cant for the life of me figure out what the hell is going here at all. i mean everything has been replaced and nothing seems to work for me. the fans do work but dont come on when the car gets to temperature.
please help i've put $1,500 au dollors into this car already in the last 3 weeks since i bought it. all the engine mounts even had to be done along with all the drop links, wish bones, inner and outter tie rods and bushings. i really dont mind putting this time and money into the car coz i intend to keep it for as long as i can plus i'll know the car is spot on reliable for me too. i've only just moved to oz so i was eager to get on the road quite but this car has put a dampper on my excitment.
can anyone help?? thanks in advance gareth ;-)
i should also mention its a 2.2 manual.
mrbishi is offline   Reply With Quote
Old 06-27-2010, 08:45 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
What's your definition of "hot"?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 06-27-2010, 09:06 AM   #3 (permalink)
THEARCHITEK's Avatar
View THEARCHITEK's Photo Gallery
r u using antifreez??
THEARCHITEK is offline   Reply With Quote
Old 06-27-2010, 09:26 AM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
antifreeze reduces the thermal capacity of water so if it warm were you are use less, does your fans kick in with the a/c on? best way to check the relays.
^ and leaving it that way!
Old 06-27-2010, 09:37 AM   #5 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
did you fill up the rad with the correct antifreeze and proper mixture?
may be different but idle or not, fan comes on my gen 3
Old 06-27-2010, 01:54 PM   #6 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
I used to have that problem. The fans didn't work. I wired them to a switch in the dash and turned them on when needed.
Chris Crash is offline   Reply With Quote
