95 Camry - Intermittent No Power/No start- Nothing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2010, 11:28 PM   #1 (permalink)
View MrCamryWagon's Photo Gallery
Got this weird problem just started happening-
Put key in ignition and nothing- like a dead battery. No lights- silence.
Open hood, everything is connected fine. (Battery is new BTW)
Get back in car, turn key, turn key.... and eventually when it feels like it- it suddenly comes back to life, starts as if there was never a problem. A little disturbing since I don't want to be stuck somewhere and not have it start. At gas station today I had asked a guy for a jump,but got it started before he pulled up. When I told him the story he said it sounds like the computer- based on his own Camry experience.
Sound familiar anyone? This has happened 3 times in the last 2 weeks.
MrCamryWagon is offline   Reply With Quote
Old 06-27-2010, 11:35 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
When the car seems dead, will the headlights for example work?
71Corolla is online now   Reply With Quote
Old 06-27-2010, 11:42 PM   #3 (permalink)
No power, lights, nothing. It's exactly like a dead battery.
The open door light isn't even on, however, I know I'm back in business because the open door light is suddenly again shining bright as ever- but only because whatever the problem is goes away by itself.
Old 06-27-2010, 11:49 PM   #4 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
Take your new battery back where you got it.
It's defective.
#2! is offline   Reply With Quote
Old 06-27-2010, 11:59 PM   #5 (permalink)
defective battery? Really? It seemed fine all winter, got it back in October.
I'd be happy if that's all it is.
Old 06-28-2010, 12:07 AM   #6 (permalink)
71Corolla's Avatar
A defective battery? Not sure I've ever heard of that happening, at least not one that goes 100% dead one minute and works the next. Your issue sounds like a bad ground actually, or a bad positive terminal connection. When the car goes dead, open the the hood, leave the drivers door open, and tap or move the connections near the battery you should be able to track down where the intermittent problem is. (you'll hear the door chime when you get a connection).
Turning on the headlights will also be a good way to tell when the connection comes back.
Old 06-28-2010, 12:11 AM   #7 (permalink)
yes, it does go from 100% dead to like new in a second.
I'll check the connections, thanks.
Old 06-28-2010, 12:23 AM   #8 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i would have the battery tested.
you check all fuses? double check
doesn't happen very often but still possible ( refer to image below: )
what work has been done to the car? (recent)
Old 06-28-2010, 09:34 PM   #9 (permalink)
#2!
This happens from internal hairline fractures. Usually from one or both of the terminal posts. This can happen with cheap batteries with poor manufacturer standards or using used batteries out of wrecked vehicles.
Complete power loss can happen completely randomly or whenever heat is applied.
Old 06-28-2010, 09:46 PM   #10 (permalink)
71Corolla's Avatar
Interesting, didn't know that. I know that a battery from a wrecked vehicle is useless though, not reliable, but never saw one go completely dead then come back to life, just would not hold a charge or would give half current sometimes. Why anyone would buy a battery from a salvage yard I have no idea. Just go to Walmart, EverReady batteries are cheap and they work fine.
