When i drive from a cold start, its like a pogo-stick. Solutions?... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2010, 04:28 PM   #1 (permalink)
Wagon Crew
swagger_wagon468's Avatar
Gameroom cash: $343652
iTrader Score: 7 reviews
View swagger_wagon468's Photo Gallery
so, when i get off work, or any time my car sits and cools all the way down...when i start my car and go; it jerks. especially if i give it a good amount of throttle. but if i let it sit while runnin for like 20 min, then its fine. is this bad?...normal? what is causing this?
94 Wagon 1MZ v6.(for those of you who dont kno what i drive)
thanks,
jonathan
Shes on her way
Tint{X} Suspension{X} Camber Bolts{X} Rims{X} Sound System{X} Rear Spacers{} Header-Back Exhaust{} CAI{} Paint/Body/Kit{} Lights{}
swagger_wagon468 is offline   Reply With Quote
Old 06-28-2010, 05:27 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Check your trans fluid.
Chris Crash is offline   Reply With Quote
Old 06-28-2010, 05:31 PM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
When is the last time you had a tuneup?
How about yer coolant temp sensor? Is it within the proper resistance range when it's cold?
Could be yer TPS is going bad...have it checked out.
Any vacuum leaks? How are those vacuum hoses looking (yes...all of them)?
How about yer air intake hose going up to the throttle body? Any cracks in that?
Shoot some vid of the problem and post it up.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 06-28-2010, 05:33 PM   #4 (permalink)
Gameroom cash: $125050
View redtigerrocks's Photo Gallery
Time to change your transmission fluid brother! I had the same problem on my Camry and on every cold start, their was a lag in shifting/lurch.
redtigerrocks is offline   Reply With Quote
Old 06-28-2010, 06:17 PM   #5 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Is it from the trans shifting or is the engine, misfiring, hesitating? Theres Not enough info to say. . .
Hold it in low up to 20mph. Shift into 2nd at 34mph. Does that change it?
When held in low, does the tach bounce as it does when cold in D?
73sport is offline   Reply With Quote
Old 06-28-2010, 07:30 PM   #6 (permalink)
Wagon Crew
well, my intake hose is actually completely ripped off but ducktaped as of now. i am replacing it with a CAI soon. i will check the vac lines tomoro...
well its not relly from, the tranny i dont think...pretty sure its the engine...
engine. ^see above. and i will take a vid tomoro.
Shes on her way
Old 06-28-2010, 09:54 PM   #7 (permalink)
V8'sRGone
73sport's Avatar
You have a 1MZ with MAF. The MAF said "six Banger, your getting X amount of AIR" but that hole in the hose let in MORE than the ECM knew about! A hole in the intake hose will F it up BAD!
Funny thing is it will idle fine, but too much torque from acceleration and the engine moves opening the crack up. Open the hood and power brake it in Drive. As soon as you apply gas the engine lifts, the CRACK OPENS and BLAH it falls on its face. Get a hose before you wreck the motor!
OK - back to the alternator. . . .
Old 06-28-2010, 10:44 PM   #8 (permalink)
Fix that. Soon. Duct tape won't do.
Alternator:
What amperage does the camry alt have? Because I found a tundra alt with 130 amps that looks like it will bolt right up!
Old 06-30-2010, 09:33 PM   #9 (permalink)
View camry6's Photo Gallery
Canada
Alternator:
somewhere around 100-110 amps. Higher amperage is better. If it has the same connections and bolts-up, DO IT!
camry6 is offline   Reply With Quote
Old 06-30-2010, 10:32 PM   #10 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Highlander alternator. Searchy.
'07 Honda Ruckus Big Bore
Old 07-01-2010, 12:17 AM   #11 (permalink)
Wagon Crew
the ONLY reason i havent got a new hose is cuz im doin a CAI very soon. (so i didnt think it was worth $40 for a new one.
Alternator:
how easy to install an alt? also, u sellin that tundra alt?
Shes on her way
Old 07-01-2010, 08:29 AM   #12 (permalink)
No I NEED that tundra alt. haha. But they're easy. Take the belt off. Two bolts. Boom.
Old 07-01-2010, 09:52 AM   #13 (permalink)
V8'sRGone
73sport's Avatar
Uhm - - bone yard - Six bucks on the steep side. On the less bright side, if your motors blown up, you won't need an alternator!
Old 07-01-2010, 02:48 PM   #14 (permalink)
slcpunk's Avatar
View slcpunk's Photo Gallery
I bought a car like that for 300 bucks once, the guy didn't know what was wrong with it. I filled it up with fresh gas, and a bottle of techron and it was fixed in about ten minutes of driving.
1997 Toyota 204k miles. Runs like a champ.
slcpunk is offline   Reply With Quote
