Where is the oil level warning switch on 3VZ-FE engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2010, 12:37 AM   #1 (permalink)
View hotspur's Photo Gallery
3rd Generation Where is the oil level warning switch on 3VZ-FE engine?
Where is the oil level warning switch on the 3VZ-FE engine (1992)?
Apparently, a mechanic left the harness disconnected from the sensor about two years ago - and today I discovered the unattached harness and plug.
The following diagram approximately locates the oil level warning switch connector (marked as item E6) near to the A/C compressor - but we have not yet found it in real life! We have looked and studied under the hood and under the engine, and also I am about worn out after several hours fruitless looking on the web for a photo or diagram.
hotspur is offline   Reply With Quote
Old 06-29-2010, 09:00 AM   #2 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
I should prolly keep my mouth shut cause I've don't know the actual answer, but I don't think it has one on the engine. There is an oil pressure switch for the idiot light.
I believe that's pointing to the AC compressor and shuts it off if low on oil. The Compressor will also be shut down if the charge is too low. Take a look at the AC compressor. Does it have a four wire plug?
73sport is offline   Reply With Quote
Old 06-30-2010, 10:11 PM   #3 (permalink)
View camry6's Photo Gallery
The oil warning switch is on the engine block, just below the A/C compressor (Not on it). It has a single wire connector on it. Just push the connector on to it.
camry6 is offline   Reply With Quote
Old 07-01-2010, 01:36 AM   #4 (permalink)
The loose harness-section and connector I have is 2-wire, not 1-wire:
I believe this is the circuit
Would you post a photo, please? I won't be able to get my car up on ramps before Friday - but when I do would appreciate knowing what the socket location looks like, especially having hunted all around that area on the engine ( as well as on the internet) a few days ago without finding the sensor/socket.
Old 05-01-2012, 09:36 PM   #5 (permalink)
View turkaljd's Photo Gallery
That picture with the wire routing that you have there is from the service manual for the ES 300 (Lexus). Though it has the 3VZ-fe, I believe that this feature is not included with the Camry. When I had rebuilt my engine (also 3vz-fe) I had looked all over for the sensor, I could not find it. Another member has a post where he had the same question about his Camry with this engine. This leads me to believe that the Camry did not come with this sensor installed in the engine. (It might be too luxurious for Camry owners haha)
Also I have run into one other instance where the only other connector that is just hanging there is the Progressive Power Steering Solenoid connector. (Balloon P2 on the next page:29) I also assumed that it should go somewhere when I rebuilt my engine but the connector was nowhere to be found on the power steering rack. Upon completion, the power steering behaved normally like it did before. There were also no check engine lights or check oil lights or whatever after I had rebuilt it. I've been driving it for almost a year since and there is no problem.
My opinion is that this is normally the situation on Camry's. Despite how old the last post was, I hope this helps should you or anyone in the future return to read it.
Dan.
turkaljd is offline   Reply With Quote
Old 05-02-2012, 12:50 PM   #6 (permalink)
That connector is not used on the Camrys, I've had four v-6 3VZ-FE Camrys and it wasn't used on either one, its just left dangling below the alternator.
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
