93 3mzfe camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2010, 02:19 PM   #1 (permalink)
GT-S Roller
brandonN's Avatar
View brandonN's Photo Gallery
93 3mzfe camry
need help identifying the problem so here is a list of stuff that is wrong right now
1. spedo cable loose(need help locating both ends)
2. Tanny sometimes slips
3. overdrive off light flashes
4.car stalls on cold start up and hesitates when trying to drive from cold expecialy when i give it gas
any help would be apreciated
Thanks
-1990 Corolla SR5 Modified, body work done and currently being painted (Girlfriends car)
-1993 Camry LE Stock with sound system Currently in the process of painting(Moms car)
-1991 Corolla LS Stock with sound system and Audi rims(Dads car)
-1989 Corolla GT-S Modified(My Car)
brandonN is offline   Reply With Quote
Old 06-29-2010, 05:48 PM   #2 (permalink)
engineer in training
Gameroom cash: $145055
Wow...
1a. Its a 3vz, the 3mz is a 3.3 liter found in newer cars
1b. Car does not have a cable driven speedo, it is all electronic.
2. The kickdown cable may need to be tightened but thats unlikely to cause bad slipping. Only cure for a slipping tranny is a rebuild. Id get a used tranny witha warranty, may fix your other problems (1b and 3)
3. Indicates an electrical problem in the transmission, probably a stuck or bad solenoid. Could be the cause of the slipping.
4. Common problem with the 3vz, you need to check the rubber part of the intake for leaks and replace vacuum lines as needed. If that doesn't fix it you need to adjust the air flow meter.
Old 06-29-2010, 05:58 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
that o/d flashing light is an error you prolly dont need a rebuild yet just a part
http://www.off-road.com/toyota/tech/codes/
get them codes!
and i have a 3mz in my 96 i put it there but i have one
^ and leaving it that way!
