Window question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2010, 05:11 PM   #1 (permalink)
View ghost111's Photo Gallery
Window question
1999 Camry LE V6. I'm have some problems with the window switch for up and down movement. How do you access the switch connections? [is it a simple mater of just lifting the little panel that has the controls mounted on it?]
Thanks
ghost111 is offline   Reply With Quote
Old 06-30-2010, 12:49 AM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
the switch itself is not damaged?
maybe bad / going bad window regulator?
you would need to remove the door panel to remove the windows / lock switch
then open the case to access the switch.
IMO i would just find a replacement
