Ok, I've been here. What a PITA if you don't know where to look! The main Car ECU is behind the glove box, Don't go there! The RS3000 alarm ECU is behind the the Side Mirror Adjust/Dimmer Knob/Security Light panel to the left of the steering wheel. To access it you just pop out the whole panel. Tucked up and wire wrapped at the very top of the opening is the RS3000 box. Mine was black plastic. It's to the right of the AC/Heater dash vent. You must cut a large black wire wrap that holds it up tight and out of the way. This will allow the RS3000 to drop down enough to reveal the magical "Green" button. To program a new key FOB# (BAB237131-022 is what I use), turn on ignition, hold the green button in for 3 seconds. the security light on the panel will light for 5 seconds, press the button on your fob that you want to use, the panel light will go out, Your done! This will work for up to 4 remotes/fobs. The "glass breakage" ECU is under the driver's side kick plate tie wrapped to the harness if you need to go there. Good luck.
