Please post photos of engine connections - 3VZ-FE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2010, 01:27 AM   #1 (permalink)
View hotspur's Photo Gallery
3rd Generation Please post photos of engine connections - 3VZ-FE
Please post photos of the connections (hoses, tubes, wires, etc) to/near the cylinder heads, valve covers and the air chamber on a standard 3VZ-FE engine. [Mine is a '92 camry.]
That will enable me to check the connections on my engine following recent replacement of its head gaskets. Since its re-assembly, my engine idles roughly/falteringly, and has poor gas mileage.
hotspur is offline   Reply With Quote
Old 06-30-2010, 09:04 PM   #2 (permalink)
View camry6's Photo Gallery
Canada
Re-check your ignition wire sequence at the distributor. The firing order is 123456. The #1 cylinder is the rear passenger side cylinder, the #2 is the front passenger side cylinder, the #3 is the middle rear cylinder.....etc. The distributor cap should have the cylinder numbers stamped on it next to each wire connection. sounds like you may have 2 cylinders mixed up.
camry6 is offline   Reply With Quote
