Originally Posted by Techniker
This was a previous post, but it does not appear to have attracted any answers, hopefully someone here will have an answer!
The questions you need answered may have been discussed in a lot of threads (especially the DIY trans flush thread by member dz63) in detail and hence folks may not have answered.
My question is this: Is there any problem with removing the outlet line from the transmission and placing it in a bottle of new ATF?
Why do you want to use suction line? Its more hassle and may be risky too. Use the return line from radiator to the transmission to pump out old ATF fluid.I used the return line and there is no problem with that at all. Make sure you have a big enough bucket. Get an 11 litres (3 gallon) bucket from Walmart ~$4 for this. The transmission pumps out fluid at a very fast rate.
A 15th quart per second at the minimum.
What is the problem with using dipstick hole to pour New ATF?
Does the transmission even have that much suction or would I have to make sure the hose is long enough that I can have the supply line above the level of the transmission?
Again you are going the difficult route...Based on my experience I would suggest its not needed.Get a clear vinyl tubing from HOme Depot with 5/8 OD X 4 ft long.
Should I even do this at all? I really think the transmission needs to be flushed because I have thrown a sticking solenoid valve code twice. There is now some Seafoam TransTune in there and I think that should be removed if nothing else.
I recently did the trans flush and man the car shifts so better now. It took 3 gallons of Walmart ATF ~ $33 and its the best money spent on my car till now.
Dont put any additives in your transmission. Its absolutely not worth it and will screw it up in the long run.
1995 Camry DX L4 178,6XX miles and counting each mile....
acquired 05/25/2007 at 129K miles
2004 Mazda6
I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
