1994 V6 Le Ac Problem Pls. Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2010, 02:58 PM   #1 (permalink)
View tondoboy's Photo Gallery
3rd Generation 1994 V6 Le Ac Problem Pls. Help
hI i'm new to this forum. I am perplexed on what the problem is for my 94 camry airconditioning. I currently had the mechanic check if there is a leak on my AC and did not find any problem. I also found out that the AC relay fuse was blown and replaced it. The problem is the AC works when the engine is cold but after running for 20 minutes the ac starts to blow regular air. In addition I had the freon recharge.
I appreciate all the help you guys can give me. Summer in Hawaii is no fun and I need my AC to work.
Thanks
tondoboy is offline   Reply With Quote
Old 07-02-2010, 04:59 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
after it starts blowing warm check the pressure might be a clogged expansion valve
^ and leaving it that way!
Old 07-02-2010, 05:17 PM   #3 (permalink)
View camry6's Photo Gallery
Canada
Thanks
Have the A/C system pressures checked. Sounds like an overcharged system.....possibly. Check the condenser, If it is dirty it will cause a high condensing pressure (head pressure). Hose it out with a garden hose, should do this once or twice a year anyway. (don't use high pressure or it will collapse the fins and block the air flow). The compressor may be tripping on it's high pressure switch, causing it to stop till it cools down. More detailed step for step chain of events will be more helpful in diagnosing the problem.
camry6 is offline   Reply With Quote
Old 07-03-2010, 04:05 AM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I currently had the mechanic check if there is a leak on my AC and did not find any problem. In addition I had the freon recharge.
Those two statements don't make sense. If the mechanic didn't find a leak why was the system recharged? OR, was the system low and recharged then inspected for leaks - and none found? Is this system R12 or 134a refrigerent? A leak in the condensor is very difficult to find. Did the "regular" air happen all of a sudden or did this happen gradually? Is the mechanic a general mechanic or A/C specialist?
A relay is not a fuse. Which relay, there is more than one for the A/C system.? Did this problem exist before the relay was replaced or after?
Blowing "regular" air could be many things. Compressor clutch, low pressure, high pressure, bad water valve, malfunctioning blend doors, air in system. You need to take it to an A/C technician when it's blowing "regular" air and start by taking system pressures and go from there.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
