Window motor help! please? lol - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2010, 09:25 PM   #1 (permalink)
JDM Inspired
Spitfire's Avatar
Gameroom cash: $122390
View Spitfire's Photo Gallery
3rd Generation Window motor help! please? lol
so tonight i go to roll up my windows after driving and no go from my drivers side. have a strong feeling that the motor is dead because i took the panel off and attempted to roll up again and no sounds no binding no heat. soo what do i do now? Since the whole piece is pretty much connected to the window is there any way to release the window from the arms while its fully down so i can atleast get it back up until i can get the new parts?
chris
Spitfire is offline   Reply With Quote
Old 07-04-2010, 12:54 AM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
did you try to "jump" the window motor
should be able to connect 12v to the connector of the motor for it to go up/down. (switch +/- wires for up/down operation)
if no go then try ebay for there window regulators. i have 2 and still going strong
not the correct way but once the door panel is off use a 10mm to un-bolt the window from the window regulator and i got vise grips to "clamp" onto the window guide (if thats whats its called) with the window all the way up...
get a second hand to hold up the window while you install the vise grips to hold the window up temporarily
i would also take a look at the master power switch for the windows and clean the contacts.
its just the driver front window?
Old 07-04-2010, 06:53 PM   #3 (permalink)
JDM Inspired
Spitfire's Avatar
well see i cant unbolt it because the window is all the way down which means the bolts are hidden behind the sheetmetal at the bottom. I think imma just take it to my shop tomarrow and have them get the window off and lose so i can buy the new parts.
