no coil problem (if you have 4 cylinder car). coils/igniters on 5s-fe serve 2 cylinders at same time (1+4 & 3+2). spark plug problem maybe ? pull plugs out and pay attention to how plug in cylinder #2 (counting from left or timing belt side as first) looks like compared to others.
also make sure that new wires "clicked" on all and both ends.
if that doesn't answer the question, i would do a compression test on engine to see if cylinder #2 compression doesn't fall out of +/-14psi range of others.
DIY camry 2.2L i4 engine 5S-FE compression test
