FML!!! Oil filter bracket leaking oil!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2010, 12:40 PM   #1 (permalink)
View sykou's Photo Gallery
this is for a 92 camry v6 le 3vzfe motor. The oil filter bracket is leaking oil. the service manual shows there is an o-ring sealing it to the block but i cannot find this part anywhere. Does anyone know the part number for this. If oil filter bracket does not ring a bell, others call it an oil filter adapter, oil filter mount, or oil filter housing. I just need to find the o-ring to fix the leak... thanks!
sykou is offline   Reply With Quote
Old 07-06-2010, 02:24 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Wink
According to ToyoDIY.com...it should be 90301-68004.
From ToyotaPartSales.com
OEM Catalog
Item Number MSRP Core Price Price
9030168005 $4.77 $0.00 $3.44
RING, O
Part number 9030168004 was superseded by part number 9030168005.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
The Following User Says Thank You to BamZipPow For This Useful Post:
sykou (07-06-2010)
Old 07-06-2010, 04:57 PM   #3 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
^ this man saved yr car fsho.
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 07-06-2010, 11:27 PM   #4 (permalink)
thanks bro! any idea what the other part numbers on the site are for?
15609 BRACKET SUB-ASSY, OIL FILTER
15671‑62020 3VZFE..VCV10..JPP 1 $149.04
90126‑08004 *** STD. PART $1.12
90179‑08183 *** STD. PART $1.18
90301‑68004 *** STD. PART $5.75
Old 07-06-2010, 11:39 PM   #5 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
it's an easy o-ring to change...mine leaked as well..no worries now u got the number just go install it urself
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 07-07-2010, 12:50 AM   #6 (permalink)
BamZipPow's Avatar
Wink
90126‑08004 is the stud
90179‑08183 is the nut
90301‑68004 is the O-ring
Old 07-07-2010, 04:54 AM   #7 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
3rd Generation
At what mileage did it start to leak oil?.......
ricamryman is offline   Reply With Quote
Old 07-07-2010, 05:47 PM   #8 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
I had to replace mine as well. I made a thread about it with pics.
Here it is....
3vz-fe oil filter adapter
Some pics I took....
http://smg.photobucket.com/albums/v4...amry/?start=20
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 07-08-2010, 03:12 AM   #9 (permalink)
nice... from what it looks like you removed yours without having to take off the downpipe? I will be ordering that oring shortly...
as for the mileage, it has 160K on it but i dunno when it started leaking oil. Just did a major engine rebuild on it so im pretty pissed about a dam oring leaking oil lol
Old 07-08-2010, 12:47 PM   #10 (permalink)
BamZipPow's Avatar
I noticed there's a 2nd smaller O-ring on the inside. I didn't see a part number fer that...yer gonna have to find something of the same size from the O-ring pile at auto parts store. Let us know what you come up with.
Also, make sure you clean the engine dirt off really well. You don't want to be trapping any micro sized particles between the new O-ring and the engine block!
Old 07-08-2010, 01:38 PM   #11 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
I did mine a while back. If I recall correctly, I had to undo the front downpipe and shove it towards the front a little bit to get enough clearance to get access to the nut and to slip the adaptor off over the stud. When ya do that, I'd recommend replacing the exhaust gasket in that joint; it's cheap, like 4 bucks.
BMR is online now   Reply With Quote
Old 07-12-2010, 04:18 AM   #12 (permalink)
k so i had to remove the front headers and push the downpipe outta the way but it was no biggie. 30 minutes and the leak is now gone for good! thanks guys!
