Never paid attention to the idle after removing/re-installing the fuse, actually. But the common sense is saying me that it should reset the ECU completely, since by removing the fuse you are cutting off the ECU's power. Same effect as disconnecting the battery. Just try, it is easy.
Edit: yes, idle is back to high after resetting ECU by fuse.
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
