Well, it sounds to me the window lock is working properly. When turned on, only the driver can control the driver window. Any other window can't be opened, from either the driver's side or any of the door switches. When turned off, all the windows should operate normally. If you have this window lock switch disconnected, or if this wire is open circuited, it will cause the same problem (this is technically a ground wire, and the switch in the off position allows the ground circuit to be completed).
Sounds like the driver door lock solenoid is defective also.
