noticed something new today - knocking? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2010, 10:42 AM   #1 (permalink)
View ps_outrage's Photo Gallery
Ok heres one I noticed, seems to only sound when I start the car cold, is the sound of knocking for about 60 seconds normal? Would this just be spark knock? I heard that some vehicles when cold produce spark knock.
Searching for rebuilt 2.2 engine
ps_outrage is offline   Reply With Quote
Old 07-08-2010, 12:01 PM   #2 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
So this "knocking" sound just appeared today? You've never heard it before today? Is the "knocking" sound very loud for a full 60 seconds, then suddenlly goes away? Or is it loud at the beginning and fades out until you don't notice it after 60 seconds? What is your oil pressure warning light doing during the time you are hearing the "knocking" sound (it the light on or out)? How long after you start the car cold does it take for you oil pressure light to turn off?
Knocking sound is something that is pretty loud & solid sounding. It that what you are hearing, or are you hearing more of a ticking sound?
93celicaconv is offline   Reply With Quote
Old 07-08-2010, 12:37 PM   #3 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
^^ Agreed - - - need those answers.
Also, turn off ALL accessories, lights, heat, AC, wipers; then start car and listen. You could also raise the hood and stick a stethoscope to the valve train and block area. DO this warm and cold listening about for differnet sounds. A wood broom handle or long screw driver works to. Place them right in your ear.
What oil wt is in it, how old is it, how, many miles (oil and engine) and what'st the outside temp?
73sport is offline   Reply With Quote
Old 07-08-2010, 02:54 PM   #4 (permalink)
i do believe the car has always done it however its really been bothering me so I thought id get a 2nd opinion. I had a 93 chevy did the same thing.
This knocking starts only on cold starts, its about 110 degrees out, oil is good. all accessories off. and it does not always last a full 60 seconds its random, could be for 20 - 60 seconds and then the knocking stops.
thats why I really think its spark knock, but then again this is not a chevy.
Old 07-08-2010, 02:56 PM   #5 (permalink)
btw i know a ticking sound and a knocking sound. ticking is always running at the engine.
Old 07-08-2010, 03:13 PM   #6 (permalink)
V8'sRGone
73sport's Avatar
Next oil change cut the old filter apart and look for bad things in the element {hacksaw}. Clean your drain pan to be spotless and drop the oil pooring the used oil into container. Now sift through the bottom of the pan. If it's loosing a bearing it should show it in the oil and filter.
don't forget the noise check with a stick. You CAN isolate noises by doing this. Cam speed is 1/2 half crank speed but wrist pin knocks can be either depending how loose the pin & bushing are.
The Following User Says Thank You to 73sport For This Useful Post:
ps_outrage (07-08-2010)
Old 07-08-2010, 03:22 PM   #7 (permalink)
ill post a sound wave of it here tomorrow. however thats good advise 73sport, ill do those steps. if i have bad bearings, easy way to fix would be
Drop oil pan and replace with new bearings?
Old 07-08-2010, 03:28 PM   #8 (permalink)
Gameroom cash: $125050
View redtigerrocks's Photo Gallery
i had the same issue but it went away after I changed my filter and did an oil change!
redtigerrocks is offline   Reply With Quote
Old 07-08-2010, 03:38 PM   #9 (permalink)
ha, whats funny is when i bought the car i installed a mobile 1 oil filter which are one of the best filters on the market, soon after i took it to a shop to get all the front end seals replaced due to leaking, when I got the car back i noticed they took my brand new oil filter off and replaced it with a cheap one. I wasnt that pissed just laughed anyways, yeah im gonna change it back to a Mobile 1 part no. M1-103
