FWIW: Cluster vs OBDII - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2010, 11:19 AM   #1 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Exclamation FWIW: Cluster vs OBDII
If you're watching the factory temp gauge for engine monitoring; I found that the Dash Needle Never Moves while actual engine temp swings from 175 to 205F!
For those who like more details, read on. . .
Local temp is 101F. Air intake through the MAF on the stock 1MZ intake is 124 to 128F. With the AC on during extended idle condtions the engine temp is 185 - 190F. With the AC off the temp increases to 205F.
The ECM reports a 7.5% Calculated Engine Load (CEL) increase to run the AC compressor and fans at idle. Idle trims are as follows.
AC ON, CEL = 26.7%, LTFTB1 = 9.4%, LTFTB2 = 7%
AC OFF, CEL = 19.2%, LTFTB1 = 7%, LTFTB2 = 8.6%
73sport is offline   Reply With Quote
