have you ever drained and refilled the ATF fluid ? it should be at least drained and refilled every 30k miles (normal conditions) or 15k miles (harsh condition, e.g. city driving only).
the differential needs to be drained and refilled every 60k miles (normal conditions) or every 30k miles (harsh driving).
how is your ATF fluid looking like on dipstick after driving (check on warmed up car after some driving), check for proper color (or discoloration), any dirt/metal particles, check proper level (should be at HIGH HOT which is highest notch) and smell it (if it smells burned change it asap).
with only 81k miles it may be still not too late for a machine complete flush on tranny (do the drain & refill on differential too at same time). i did it at 64k miles and was having similar symptoms to yours (plus was seeing some dark grey dirt on dipstick). though i drained & refilled the differential quite recently at 74k miles.
