you dont need to drain the engine oil had mine changed 3 times never drained, tranny yes engine no.
it easiest to remove and do everything by dropping the sub frame, just get jack stands to hold it up.
leave the engine in the car support it with a 2x4 across the top and some chains
remove the axles including the rear jack shaft, unhook everything from the tranny unbolt and yay!
you can remove it from the top if you have too, it takes long and there more to remove, basically dont drop the sub frame but do everything i listed plus remove the hood and everything over the transmission
^ and leaving it that way!
