Visual of Bad Inner Tie Rod - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2010, 01:25 PM   #1 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Exclamation Visual of Bad Inner Tie Rod
Just so you know what it looks like when you find worn suspension parts and people say to grab the wheel at 9-O'clock and 3-O'clock here is a sample of a bad inner tie rod joint at the rack and pinion. These were new after market t/r @ 142,000 miles. Car has 223,xxx on it now.
I have the parts but haven't had time to put them in as it will require me pulling the rack out. Yes, I'm sure it could be done w/out yanking it out, the damage to gear mesh area of the pinion gear would likely be the end result.
This little movement here:
Translates to this movement here, watch the tire fender motion change
Oh - for those of you that say any worn parts make the car shake, this car doesn't. Car is completely vibration free at all speeds having "no shakes, no vibes". Out of round, out of balance, bent wheels, bad tires, ect make things shake. Tight parts help control the shake.
- I'll do a right up when I pull them out and followup w/DIY toe adjustment.
73sport is offline   Reply With Quote
Old 07-11-2010, 01:57 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
thanks man, this helps
Old 07-11-2010, 02:17 PM   #3 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
Thanks a ton 73sport. Will you need a visit to alignment shop after replacing the parts? Or Planning to use "73sport Manual Alignment Machine" ha ha :-)
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 07-11-2010, 02:38 PM   #4 (permalink)
V8'sRGone
73sport's Avatar
Those tires have 5 or 6000 miles on them on the front of the car with the trashed parts and the tire wear is pretty normal. Why, the average toe is basically on the mark. . .
Answer - won't pay them! I'll use the money for something else. . .
Old 08-19-2010, 06:47 PM   #5 (permalink)
V8'sRGone
73sport's Avatar
Connecting the Dots
Here are some related links to the Stickies which will guide you through the repair process if you have this problem.
DIY: Inner Tie Rod Replacement, Rack Removed Lots of PiX!
DIY Rack and Pinion Removal/Install, Flush and Toe, Lots of PIC's!!!!
<< bad parts thread >>
Ya get what ya pay for . . . aftermarket parts
Old 08-19-2010, 06:53 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
very nice visual man. good work
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-20-2010, 03:06 PM   #7 (permalink)
V8'sRGone
73sport's Avatar
Thanks Rob!
Now if we could only decide what to do with these aging rides. . .
