Bearing noise? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2010, 06:43 PM   #1 (permalink)
Gameroom cash: $125050
View redtigerrocks's Photo Gallery
3rd Generation Bearing noise?
I recently changed my ALT/AC. belt and I've been hearing a loud pitch squealing all of a sudden. The squealing gets louder as I rev past 2k RPM but dies down when I hit 1k RPM. I'm not sure whether its the belt or its a bearing inside the alternator. Any suggestions? I might post up a video later tonight
redtigerrocks is offline   Reply With Quote
Old 07-11-2010, 07:01 PM   #2 (permalink)
Thats what it sounds like just idling...
Old 07-11-2010, 08:48 PM   #3 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Did you adjust to the proper tension per spec? If oil was spilled on the belts, pullies, that could cause noise.
Take wooden stick and place to your ear. Let it idle, listen, then rev and listen. Try to keep your ear out of the pulley and listen to all the different components. You might need a helper. But bad bearings will scream in your ear if bad...
73sport is offline   Reply With Quote
Old 07-14-2010, 04:53 PM   #4 (permalink)
Bump still making noise... Does not removing the neg. cable of the battery during the change of the belt harm the alternator?
Old 07-15-2010, 12:04 AM   #5 (permalink)
BUmppppppp
Old 07-15-2010, 12:26 AM   #6 (permalink)
View donhuynh's Photo Gallery
You can turn on the ac to make the clutch engage to check the ac clutch bearings and you can disconect the connector that plugs in the altenator and hear the noise change. the noise seems to be the alternator to me but not sure. good luck man
donhuynh is offline   Reply With Quote
Old 07-15-2010, 12:31 AM   #7 (permalink)
Whenever i put the AC on or put a load on the alternator the noise dies down and virtually goes away. I seriously think its the belt though..
Old 07-15-2010, 12:53 AM   #8 (permalink)
View toyotatech671's Photo Gallery
sounds to me like it needs to be tightend.
toyotatech671 is offline   Reply With Quote
Old 07-15-2010, 09:42 AM   #9 (permalink)
V8'sRGone
73sport's Avatar
Anti - Bump
Any answers and maybe some help could be provided?
