tranny issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2010, 09:27 PM   #1 (permalink)
03 le /93 le
View eddyroz6's Photo Gallery
tranny issues
hi ppl im new to this so i'll try to be s.a.s (short and simple) 1993 toyota camry le 2.2l 4 cylinder with about 198k motor rebuilt two years ago .... all of a sudden the car is leaking oil from the tranny ,,,,,near the safety neutral position switch and it only goes in reverse it does not drive in d,2,l . i need this car for work . someone please help and thank you for reading ....
eddyroz6 is offline   Reply With Quote
Old 07-12-2010, 04:32 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
sounds like a bad seal, this will likely require removing the tranny and replacing it. what color is the fluid?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-12-2010, 09:19 PM   #3 (permalink)
03 le /93 le
the fluid is brownish with a reddish hue to it . does that make sense . is it true that i have to remove the frame from the bottom and the engine to get the tranny out ?????if it is so can it be accomplished with truck jackstands? ohhhh by the way thanks for responding where you from?///?/
