I have a 1993 Camry LE with 162K miles on it. A few days ago, my car died at the last stoplight on my way home from work. It would continuously crank, but wouldn't fire. Had to get some help to push the car 1 block to my place.
My mechanic friend re-adjusted the timing/timing belt in order for it start up again. But then ANOTHER issue came up. This time the car sputters & dies during idle and while test driving.
Needless to say, it's not a pleasant experience with cranky California drivers all around you.
This past weekend, I:
-replaced the spark plugs
-replaced the fuel filter
-cleaned out the throttle body with B12 (seems to have helped with the sputtering during idling)
-got a new air duct for the throttle body since there was some tearing on the old air duct
-added B12 fuel injector cleaner into my gas tank
-checked resistance of the ignition coil and it matched up to the ohms range listed in the Haynes manual.
I have no idea where else to look. Anyone out there with any other ideas?
