Examples of setting up CAI - Need advise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2010, 07:13 AM   #1 (permalink)
View ps_outrage's Photo Gallery
got a SRI already planning to convert to CAI today, need help or advise were to run the tube from cone to ?, i want to angle the tube downward and slightly curved to prevent water from being sucked in. However i would like to plan the setup before installing. so if anyone has setup a CAI up, what is the best way to run this tube
Searching for rebuilt 2.2 engine
ps_outrage is offline   Reply With Quote
Old 07-13-2010, 12:01 PM   #2 (permalink)
Gameroom cash: $115300
View TCam01's Photo Gallery
There's a resonator box in the driver side fender like right under the fuse box you need to take the resonator out and extend the pipe down into the wheel well area. I think i did exactly what your trying to do i have one pipe that extends the sri down into the wheel well far enough so i could put a coupler and clamp on another curved pipe to it making it go down far enough so the filter could go on.
Yota Camry 2001 5S-FE 105,430 Miles+
TCam01 is offline   Reply With Quote
Old 07-13-2010, 05:22 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
best solution to get the best of both worlds is to use your stock air box as a plenum if you can. cut a hole in it so you can set the filter in there then run tubing into the fender to take in cold air. this way you get cooler air, the advantages of a cone filter and dont have the loss of high end power due to friction....OF course none of this really makes any differance on our NA engines so you could stick with your SRI and be just fine.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
