A/C Compressor Oil? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2010, 10:18 AM   #1 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568401
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
A/C Compressor Oil?
So I was chatting with a co-worker who dropped his car off for A/C service this morning, and he was telling me something about A/C compressor oil. I told him I had never heard of such a thing, and I've never read anything about an a/c compressor needing new oil or anything of the likes. I decided to step back into the lab with him and I ran a quick search for my car and here is what I found for my car:
http://www.drivewire.com/search/?Ntt...e&t_event=true
Apparently, it does exist. Now my question is the following: Should I consider paying up for this stuff? Is there any way I can change this "a/c compressor oil"? I'm kinda skeptical about all of this....
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 07-13-2010, 10:46 AM   #2 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
No need to change compressor oil
AliRazoR is offline   Reply With Quote
Old 07-13-2010, 10:48 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
does your a/c work? yes? then no. it's a sealed system with a filter it never needs to be changed unless your compressor murders it self and the oil is now filled with metal shaving (my dads ford did that) or you own a ford where the teflon coating inside the compressor flakes off and screws the oil (ford has fixed the problem by stop using teflon).
point is only reason we really ever change the oil in our cars is because we have blow by from the compression chambers where the smaller hydrocarbon chain helps break down the oil (and then that break down is sucked out through the pcv), and dirt gets in the system from holes like the filler cap, oil dip stick, pcv system.
i think i'm still drunk... but ya scam to go change compressor oil.
oh when you do buy a new compressor they are shipped fill with oil that needs to be drained and then refilled to the proper level per fsm specs(auto only home (electric) units are pre oiled but to the correct amount)
^ and leaving it that way!
Old 07-13-2010, 01:39 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
You'll only need the compressor oil if your A/C compressor lost all it's freon or you are installing a new compressor.
I replaced the compressor in my MR2 last summer. The compressor came with a bottle of oil.
The Jedi Speeder at CarDomain
Old 07-13-2010, 01:42 PM   #5 (permalink)
TN's Mad Chemist
Thanks for the clarification guys I knew there was a good reason why I was skeptical of what he was telling me! He was trying to convince me that because my car had so many miles, I should consider getting the compressor oil changed, and I pretty much said what chronoti said. My A/C is working and blows ice cold air. If it ain't broke, don't fix it!
1997 Acura RL-Gone
Old 07-13-2010, 01:46 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Exactly!
Old 07-13-2010, 02:25 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
as guys say, if it works forget it. you only need a can of a/c compressor oil when you emptied the system (including oil).
on a side note, when shops do a/c vacuum service the machine sucks out the gas only leaving oil in. however when you release the gas yourself through the fill valve it will likely loose freon together with oil (same happens if you have a major leak).
cheers.
Old 07-13-2010, 06:33 PM   #8 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
There is a fixed amount of oil in A/C systems. Leaks in the A/C system, when the A/C system is running, will also discharge a small amount of oil. Typically no need to add oil unless one recharges the A/C system once or twice every year and never has the leak repaired. Eventually, the leak will take out too much oil and there will not be enough in the system. Also, if a major part (beside the compressor) is removed, like the condenser, evaporator, receiver/dryer, accumulator, etc., is removed and replaced, these items hold small amounts of the systems total oil supply. A supplemental oil addition should be made when these major pieces are replaced in an A/C system.
93celicaconv is offline   Reply With Quote
