Camry A/C Problem???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2010, 10:43 AM   #1 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
4th Generation Camry A/C Problem????
I have camry 2002, 5sfe engine
My A/C button is flashing, what should i do?
AliRazoR is offline   Reply With Quote
Old 07-13-2010, 10:52 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
check your belt tension, then look at your pressure switch should be near the battery next to the sight glass on the receiver/dryer
^ and leaving it that way!
Old 07-13-2010, 11:06 AM   #3 (permalink)
Banned
how can i check the belt tension, i don't have that tool
Old 07-13-2010, 11:32 AM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
auto zone tool rental? or just push it with a ruler an have another stick to measure the movement
http://www.ehow.com/how_2350791_chec...rive-belt.html
Old 07-13-2010, 11:34 AM   #5 (permalink)
Banned
By the way i do not think the problem is belt, some one told me the problem is ECU
Old 07-13-2010, 12:29 PM   #6 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Wink
How did they come up with that analysis?
You haven't given us enough information. Is the AC clutch engaging? What did the sight glass look like? Are there any noises coming from the compressor?
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
Old 07-13-2010, 12:42 PM   #7 (permalink)
Banned
every thing is OK
i changed the compressor with new one(toyota original part)
i changed the receiver dryer, MG/CL relay, expansion valve
by the way the belts are new
Now tell me what is the problem with these information(BamZiPow)
if you know
Old 07-13-2010, 01:11 PM   #8 (permalink)
96 3MZ M/T
chronoti's Avatar
new belts expand and need to be readjusted a few months later, the ecu doesn't control the ac
there is a separate unit called the ac amplifier
most likely it's being caused by the pressure switch on the receiver
Old 07-13-2010, 01:13 PM   #9 (permalink)
Gameroom cash: $160515
View mdatrdcam's Photo Gallery
did it start flashing after you drove through a really big puddle, or the engine/underside of the car came into contact with a large amount of water? after driving through a really big area of standing water the a/c button started flashing in my gen 3.5. it eventually stopped flashing after i turned the a/c off, let it dry out a little then turned it back on. i have yet to have it happen in my 2001. i know thats not really any help, just trying to help you diagnose the problem.
FULLY LOADED 01 V6 5-SPEED-INJEN INTAKE-TRD QUICKSHIFTER-FULL TRD SUSPENSION-TRD STRUT TOWER BAR
mdatrdcam is offline   Reply With Quote
Old 07-13-2010, 01:17 PM   #10 (permalink)
Banned
i do not know what is the pressure switch!
camry 2002, 5sfe engine DOES NOT HAVE AC AMPLIFIER.................................
Old 07-13-2010, 01:19 PM   #11 (permalink)
Banned
No,it is not water
Old 07-13-2010, 01:40 PM   #12 (permalink)
96 3MZ M/T
chronoti's Avatar
your right sorry the v6 has the external amplifier
you can see where the pressure switch is here
Old 07-13-2010, 01:43 PM   #13 (permalink)
Banned
my friend this is thermistor.i checked this as well.
if you see the image it is written ECM(or ECU) as i told you.
by the way i have this toyota repair manual.
Old 07-13-2010, 02:25 PM   #14 (permalink)
View hzt30's Photo Gallery
Flashing A/C light
Other than the A/C light flashing, does the system work? Blinking A/C light usually shuts down the compressor and could indicate a problem with the RPM sensor in the compressor.
I have a 2000 5sfe and the A/C light flashes but the system works 100%.
hzt30 is offline   Reply With Quote
Old 07-13-2010, 06:28 PM   #15 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
HTZ30 hit it on the head. A flashing A/C light means the A/C amplifier detected slippage between the compressor and the crankshaft. Toyota A/C compressors have an RPM sensor for this very purpose. Problems causing this could be loose belt tension, water on the belt, an A/C compressor clutch not fully engaging, or the A/C compressor is turning much harder than it should. The A/C flashing light is an A/C failsafe system, so when the A/C amplifier detects slippage on the A/C compressor, it does shut down the A/C system to avoid the potential of further damage.
93celicaconv is offline   Reply With Quote
