Originally Posted by njwrestler07
the steering wheel, i feel everything in the steering wheel and also the rest of the car shakes because of how bad it is. when the car isn't moving, and i turn the steering wheel left and right pretty quickly, the steering wheel clicks. I feel that when i'm driving at high speeds when the wheel is straight.
You might want to start here with that click even though its beyond the date range.
Old Recall notice for Loose Nut! READ
Short of finding something bent, or completely shot (worn oput), please use the search button. In the end almost all vibrations come back to tire/wheel issues. Yes, many will claim things get better with lots of new parts. The fact is the new parts mask the real problem which is often a bad tire or a bent wheel. If you spin the tire ON THE CAR and they do not follow a perfect circle with no side to side or lateral run-out you need to find the source.
I suggest you chuck up these wheels and test them for lateral run-out, and confirm they center properly on the hub. Are these factory steel wheels? If aftermarket, do they have hub centers on them so the studs are not the only thing trying to center them?
Also, please be more specific about the vibrations. Denoting what the front does and what the rear does.
Something else to consider is sometimes people put shims under the rotor hats to corrects rotor run-out so the brake don't shake. You might consider pulling the rotors ad removing them. Perhaps replace the rotors if you find shims.
