Right. If you are lucky, the block sealer will temporarily help your current situation for a short time until you fix it the right way - but in the mean time, you are plugging up other areas (like the radiator, heater core, deposits in the block cooling jackets, etc.), that will mean a lot of extra work to correct as well. I've used coolant sealers before and then took an engine apart. Once you see what it does, you wouldn't use it again.
Sorry to hear about your situation. But it does sound like a headgasket gave out.
