spark plug torque questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2010, 11:54 PM   #1 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
sorry its me again.
i used a torque wrench on my 2 4 6 and 1 5 cylinder spark plugs.
but freakin i couldn't get the torque wrench into the middle rear plug so i kinda just winged it with my rachet. is that ok ? =[
thanks a lot,
d
oh btw the bosh plugs say 21 ft lbs and the haynes manual says like something a lot less. i went with the 21 ft lbs. is that too much ?
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 07-14-2010, 12:32 AM   #2 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
Best thing you can do is remove those plugs. Bosch & Toyotas DO NOT MIX. Seriously, you should only be using NGK plugs on Toyotas. Generally when tightening plugs, you can do it with a ratchet, once the plug meets the engine block, make a 2/3 turn. !ome reccomend applying anti-size on the plug.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 07-14-2010, 01:06 AM   #3 (permalink)
yuu think so ?
what a waste of 40usd that would be =[
i guess i should've gone w the ngk in the first place. ugh
^^^ List of my mods
Old 07-14-2010, 01:21 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
13-15 ft lbs is enough.
Just use the plugs you got for alittle while till you get some NGK's. Then dump the Bosch.
For some reason they just don't last or perform for Toyotas.
The Jedi Speeder at CarDomain
Old 07-14-2010, 01:26 AM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
yeah thats what i did too a year ago. my bosch plugs landed in garbage after a month as car was feeling real sluggish with them (were trying them with both bosch wires and then NGK wires, no change). with NGK plugs & wires it accelerates so much better
i don't know v6 torque specs for plugs, but for 4-banger 5s-fe it is 13ft-lbf.
Old 07-14-2010, 06:35 AM   #6 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
I used Bosch plugs once also, and not for very long. Engine ran very poorly. Either Denso or NGK plugs work much better on Toyota engines. I use NGK, but there are a lot of people who feel Denso are superior. All I know is that Bosch plugs don't mix well with Toyota engines.
I also coat the plug threads with anti-seize, then use the 2/3rd turn after plug mates with head routine - no torque wrench.
93celicaconv is offline   Reply With Quote
Old 07-15-2010, 11:44 AM   #7 (permalink)
View djb2's Photo Gallery
The torque is likely fine. After doing five with a torque wrench, you had a pretty good feel for the correct torque.
Some engines require the plugs to be installed dry, others with a drop of motor oil. Few recommend anti-seize.
djb2 is offline   Reply With Quote
Old 07-15-2010, 04:38 PM   #8 (permalink)
Gameroom cash: $167485
View haux's Photo Gallery
I personally have not noticed any difference in performance on my I4 with Bosch plugs. Bosch is basically what I went with every plug replacement until I heard people talking smack about it here.
However, with all of the what people here are saying about Bosch, I'd stay away from them.
If money is an issue, don't just throw them away. Use them and decide for yourself if they're crappy. Then in a year get NGK.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 07-15-2010, 05:34 PM   #9 (permalink)
ok thanks a lot guys. i'll get some ngk plugs soon.
and thanks for confirming that my torques should be ok.
^^^ List of my mods
