Gen 4 5SFE alternator on a gen 3 5SFE
I recently had problems with a rebuild on my 94 Camry 4 cylinder 5SFE's alternator. After several attemps to rebuild the original unit resulted in vey short life each time, the alternator always smelled like it had been burned, just like the first time I brought it in. The last time it lasted only a day. After checking some books the rebuilder had in the shop and checking another alternator that looked brand new that the rebuilder had in the shop, he said why don't you try this one. It's a 90 amp alternator for the 97-01 Camry 4 cylinder engines. Your alternator is a 70 amp. The altenators were the same size. All connections were the same and the pulley was the same width and 5 rib belt design. The only difference was the pulley was about 1/16 of an inch bigger in diamenter. Not a problem. It's been on my car for about 2 weeks and a hundred miles and appears to be working fine. I was just wondering if anybody else has done this swap and what were the long term results.
Thanks for responding.
Mike
