93 camry power mirror shell replacement
Hello, I have a 93 XLE sedan that I need to replace the right side mirror. The power movement operates OK, The problem is the previous owner replaced the green mirror with a gold color.
I'm trying to avoid painting mine by buying a used one in green, and swapping internals if needed.
If I buy one do I need to ensure the replacement is from an XLE, or will any 92-96 Camry fit?
I read the XLE has heated mirrors. (never checked mine) Again, can I use any model Camry mirror shell and swap my internals? Thank you for your time.
