'92 camry wont start/died
Hi guys, I'm new to posting here but i have used your information a lot over the past year with my car and unfortunately I have hit a wall (not literally).
I have a 1992 camry LE 2.2L That I did an engine swap on to a '93 2.2L. The car has run fine for the last 5 months or so until last night as I pulled up to a stop light, the car just died on me. The battery has enough power to turn over the engine, but its not firing for some reason. I loosened the hollow bolt on the fuel line to check fuel pressure, but it seems to be fine as fuel will squirt out when i try to crank it. I also sprayed starting fluid in the intake to test the spark/timing and it would fire once and then die again. Can anyone help me figure out whats going on with my beloved toyota?
