Camry (gen3) Instrument Cluster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2004, 07:34 AM   #1 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
Question Camry (gen3) Instrument Cluster
Hi,
Im from Australia, and I want to upgrade my instrument cluster to one from a higher grade Camry.
the gen3 Camrys in Aus, only had the Auto Trans Indicator (P,R,N,D,2,1) in the instrument cluster for the higher grade models. My cheapo Camry model didnt have this.
I am able to get this cluster from a junk yard, but would it work in my car? and do i need to replace the whole cluster, or just insert the indicator into my existing one?
thanks.
~ Terry
terrynham is offline   Reply With Quote
Old 04-03-2004, 09:52 AM   #2 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
The PRND2L vertical display is a module in the Gauge Cluster. It can be pulled out from the back. The only thing holding it in is a tab that you need to push down, and the cable that attaches to it. Also, you'll wanna take the overlay on the front of the cluster that has the vertical rectangular shape cut out.
Lemme know if I wasnt clear enough.
ratko.org
Ratko is offline   Reply With Quote
Old 04-03-2004, 10:34 AM   #3 (permalink)
nub
spydrvnm's Avatar
View spydrvnm's Photo Gallery
i think he needs to know if it will work properly when put into his car.
spydrvnm is offline   Reply With Quote
Old 04-03-2004, 11:09 AM   #4 (permalink)
it was all a dream
You will have to check the back of your current gauge cluster to see if it has a plug for the Gear Indicator module... if not, then youre outta luck. But I believe it should be tucked in behind there regardless, or it would have cost Toyota much more money to make different harnesses for something as trivial as a gear indicator.
ratko.org
Old 04-03-2004, 12:13 PM   #5 (permalink)
nub
spydrvnm's Avatar
yeah that makes sense.
just do that before you go to the junkyard
Old 04-03-2004, 05:59 PM   #6 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
yeah, i installed a Digital Clock and Glovebox light a little while ago and their were plugs ready to be used for them.......so i assume it shouldnt be any difference for the gear indicator lights , but ill check anyway.
also would you reckon that there would already be wiring for something more extravagant like Power Windows?
~ Terry
Old 04-03-2004, 06:10 PM   #7 (permalink)
nub
spydrvnm's Avatar
do you have power locks? i've never ripped my door apart so idk if that harness is together but possibly.
Old 04-03-2004, 06:16 PM   #8 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
yeah, i got power locks.
~ Terry
Old 04-03-2004, 06:20 PM   #9 (permalink)
nub
spydrvnm's Avatar
if you feel fine takin your door panel off that might be a good idea to see if it does
