Ac light flashing!!!!!!!!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2010, 11:06 PM   #1 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
Wink Ac light flashing!!!!!!!!!!!!!
camry 2002, 5sfe engine, 4 cyl
when i turn the ac on the ac button start flashing
but when the car is hot(the car temperature is in the middle) it works perfectly.
AliRazoR is offline   Reply With Quote
Old 07-18-2010, 12:06 AM   #2 (permalink)
Wagon Crew
swagger_wagon468's Avatar
Gameroom cash: $343652
iTrader Score: 7 reviews
View swagger_wagon468's Photo Gallery
does the AC work fine when the light is flashing?
Shes on her way
Tint{X} Suspension{X} Camber Bolts{X} Rims{X} Sound System{X} Rear Spacers{} Header-Back Exhaust{} CAI{} Paint/Body/Kit{} Lights{}
swagger_wagon468 is offline   Reply With Quote
Old 07-18-2010, 06:57 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Other than checking the A/C belt tension there's not a lot you can do without test equipment and an understanding of the operation of the A/C system. As AliRazoR asks, you didn't tell us if you're getting proper cooling when the light blinks.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-18-2010, 09:45 AM   #4 (permalink)
Banned
it is not getting cold when the ac is flashing(the compressor clutch will be off )
Old 07-18-2010, 09:56 AM   #5 (permalink)
Possibles; low pressure, high pressure, low pressure switch, high pressure switch, clutch relay, clutch coil, clutch plate spacing, revolution counter, TXV valve, A/C amplifier.
Old 07-18-2010, 10:05 AM   #6 (permalink)
Banned
Where is the pressure switch
Old 07-18-2010, 10:57 AM   #7 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
Camry A/C Problem????
seriously?
^ and leaving it that way!
The Following User Says Thank You to chronoti For This Useful Post:
LynchburgCSI (07-18-2010)
Old 07-18-2010, 12:26 PM   #8 (permalink)
ydopen's Avatar
View ydopen's Photo Gallery
My 95 starts flashing and quits blowing cold sometimes. My mechanic told me to swap out the ac relay in the fuse box under the hood?
11 Camry Se 4cyl,
95 Camry v6 17in o8 camry wheels. Tint.
83 toyota pk. Longbed automatic all-original.
98 Expedition 16in rebel racing black rims.
01 Chevy Metro
ydopen is offline   Reply With Quote
Old 07-18-2010, 12:29 PM   #9 (permalink)
Wagon Crew
^at chronoti^ o wow
thats just rediculous
Shes on her way
Old 07-18-2010, 04:13 PM   #10 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
Toyota A/C compressors have a speed sensor on them. When the A/C amplifier determines that the relative speed of the A/C compressor is not appropriate for the speed of the engine, it shuts down the A/C system (at least for awhile, depeding upon model and year) to avoid serious damage to a component. Potential causes for this type of problem is a loose belt, an old and glazed belt, a worn A/C clutch, an improper retrofit of an R-12 system to R-134a, or the A/C compressor bearings or internals failing.
93celicaconv is offline   Reply With Quote
