Originally Posted by zappa1999
2000 camry 171K died on side of the road with no water in radiator. We replaced water pump and timing belt. Next day temp went to hot after less than 2 miles driving it. Filled it all back up with coolant and when I let it run 10 to 15 mins, no fans and temp guage all the way hot. Checked relays all seem good. The fuses behind coin tray are not marked and I can not find anything on them. Not in user manual or Chilton. Do any of these have anything to do with fans or relays?
Thanks.
OK, 5S-FE 4-cylinder. Still read through the thread that Nervous provided. You might get some useful stuff from reading that.
Engine died while driving on the road when there was no coolant in the radiator? Why did the engine die, from overheating? Dumb question here, but if the temperature gauge was pegged at hot, why was the car allowed to continue running? And where did the coolant go? Was the water pump leaking badly?
Put a new water pump and timing belt in, drove it the next day, temp gauge went back to hot quickly...and you lost a bunch of coolant that required you to "fill it all back up again"? Did you have another leak somewhere? Where is all this coolant going?
I'm sure we can check the reasons why your fans are not running, but my first main question is where is all that coolant going. And, if you are driving during all this time, the fans don't typically come on, because the radiator is getting plenty of air to cool off the coolant while driving without the need for the fans to run. And you said the first 2 times that you were driving.
What work was done to this 2000 Camry immediately preceding the loss of coolant and overheating situation?
