Hello, my father and I have been having a real problem with my 96 LE V6. It has 190k on it and there has been a problem when the car warms up.
The car runs absolutly perfect when it is cold. But once it warms up, it seems like something gets to hot or a sensor is bad so it restricts the motor to only rev up to 2,500 rpm. We have checked all sensors and believe all the grounds are correct. Could this have something to do with the coil packs? Or any other ideas?
Because it governs at this low rpm, the car only goes up to about 60 miles per hour. Its really weird because other than the governing/cutting out, the car runs perfect!
I dont think it would be the throttle body because it revs just fine before it turns warm. Isnt there a cold start phase in the camry where it delivers more fuel at first then cuts back when warm? Could it be injectors?
Cam position sensor has a direct link to proper fuel injector operation. A bad cam sensor could cause injectors to operate slightly off (but not the other way around). I would start by testing that sensor. You could also pull out the front 3 injectors and take a look at them.
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
That puts the ECU in extreme limp mode because it's an integral part of the ignition and fuel injection system. If the ECU couldn't compensate, it'd stop all ignition and injection.
FYI, the resistance of the sensor changes from cold to hot, so it's possible it's in spec when cold, and out of spec when hot.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
How would I test this sensor? We let the car warm up to where it messes up, shut it off, tookthe sensor off, cooled off the sensor, then put it back on the car and started it really fast to see if it worked for a second while it was still cooled down. but it didnt fix it
I thought cam sensor just determines injector firing order no?
Interesting, I didn't know it had 2 modes, althought it does make sense...
1997 Acura RL-Gone
Mainly it does, but the ECU needs the signal because the 1MZ uses electric/direct ignition. At least the crankshaft position sensor is there as a backup. When the sensor fails, the ECU moves to asynchronous injection (worse than batch fire), so all injectors fire to ensure the engine can still run.
Usually the distributor houses the cam position sensor.
1991 Toyota MR2 V6
Any pointers on how to check?
Measure the resistance (Ohms) of the sensor's terminals with a multimeter. I'll give you the values.
Denso made cam position sensor:
Cold - 835-1400 ohm Hot - 1,060-1645 ohm
Wabash made cam position sensor:
Cold - 1,690-2,560 ohm Hot - 2,145-3,010 ohm
The ECU is calibrated to accept both since they use different functional values.
1991 Toyota MR2 V6
I ought to sit down with you and 73sport one day so you can dispense yor full wisdom to me
So one more (maybe noob) question: Wouldn't the engine run better in this scenario if it relied on the crank sensor instead of going into asynchronous injection? I mean, crank sensor measures with cylinder 1 is at TDC no? Or have I forgotten my basic principles here
1997 Acura RL-Gone
Commonly refered to has a hand held volt meter, DMM (digital multimeter). They measure DC volts, AC volts (RMS), Diode break down voltage, Current nad sometimes even temperature.
The meter has test leads and you set it ohms, verify your test leads when open read infinite ohms and when the leads touch read Zero ohms or at least less than 2 - 3 ohms. Subtract the the shorted # number from your actual test and/or use the Zero function if the meter has it. Also, your body and other materials are conductive so YOU as living being can effect the measurement by touching the leads with your fingers.
Buy one, learn how to use and you'll find all kinds of uses for it.
