Gen 3 5-speed V6 Parts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2010, 09:42 PM   #1 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
3rd Generation Gen 3 5-speed V6 Parts
Figure I'd make a DETAILED list of all the parts needed, and optional, for a swap. This is not everything. But will be updating it.
E-brake swap parts
Center Console (Handle type from a Gen 3 I4 or V6 SE):
Handle and Cable with both nuts and lower plastic piece (not in picture) (Handle type from a Gen 3 I4 or V6 SE):
Hydrolic Parts
Master Cyl (Gen 3) (Still on pedal in picture):
Lines with Slave Cyl and Valve (Gen 3):
Pedals/Shifting
Brake Pedal and Clutch Pedal (with sensor) (Gen 3 5-speed):
Mounts/Axle's
Axle's (Gen 4 V6 (E153) 5-speed Axles):
Gen 3 I4 (S54) or V6 (E53) shifter base and V6 (E53) Shifter Cables:
Gen 4 V6 5-speed rear mount (new snap ring and screw optional but recommended):
Side Tranny mount with Plate (Gen 3 E53 or Gen 4 E153):
Tranny Parts (No, not THAT type!)
E153 Tranny:
Clutch:
Flywheel:
Fork, Boot, and Pivit screw:
Throwout Bearing, Flywheel Bolts, and Clutch Bolts (E153):
OPTIONAL
Shifter Base and Cable Brass Bushings:
Gen 3 I4 (S54) tranny mounted clutch line. From what I can tell, it will delete the valve (causes a delay and crap pedal feel) with very little bending (New line in pic):
5 Lug Corolla WHAT?
Old 07-19-2010, 11:54 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
nice..
i want a damn 5 speed
Old 07-20-2010, 12:00 AM   #3 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
optionnal but you can get a manual cluster so you get rid of the auto gear indicator!
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
Old 07-20-2010, 12:04 AM   #4 (permalink)
It;s not just a simple swap for that. You can;t use the 3VZ cluster or the 5S cluster as the Tach is different. You can likely combine them to make one perfect working one though.
5 Lug Corolla WHAT?
Old 07-20-2010, 12:06 AM   #5 (permalink)
redneck engineer
lemegacool's Avatar
what i've meant to say is just to mod your existing cluster with the manual one (assuming the manual one is a gen3)
Old 07-20-2010, 12:48 AM   #6 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
subscribed.
'07 Honda Ruckus Big Bore
Old 07-20-2010, 12:55 AM   #7 (permalink)
This stuff is all for another member on here doing a build. Thats why I don;t have pics of the tranny or clutch as he got them. I have one axle for him but still need to get the other. I;ve been doing hardcore research to get every nut and bolt needed.
5 Lug Corolla WHAT?
Old 07-20-2010, 12:57 AM   #8 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
Pedals/Shifting
you do NOT need the full mount for the brake i was able to just use the peddle arm i still have the auto switch and upper hard ware.
Mounts/Axle's
Gen 3 XLE and ES300 axles work for the driver side you need the stub axle from one that DOES have abs, it's longer dont ask, i have no idea on the rear jack shaft i used a gen 4
one more good optional is the extended throw push rod for the slave cylinder
^ and leaving it that way!
Old 07-20-2010, 07:42 AM   #9 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
Hey Adam I believe you mean the S51 right? S54 was celica/MR2.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 07-20-2010, 10:52 AM   #10 (permalink)
96 3MZ M/T
chronoti's Avatar
actually he means the s53, the solaras got the s54 in like 2k something
Old 07-20-2010, 11:09 AM   #11 (permalink)
Bdub215's Avatar
never seen the S53 in anything other then the 5th gen celica (90-93) or swaps. dont forget the s53 and the s54 were close ratio boxs. the s51 was the long ratio box better for the camry for fuel economy.
Old 07-20-2010, 04:25 PM   #12 (permalink)
96 es300 2mz-fe
Gameroom cash: $135325
View Brandoe91's Photo Gallery
Don't forget the e53 tranny.That's an option that others used as well.
Brandoe91 is offline   Reply With Quote
Old 07-20-2010, 04:50 PM   #13 (permalink)
Bdub215's Avatar
That's the v6 manual. I'm on about the 4cyls manual.
Old 07-20-2010, 04:54 PM   #14 (permalink)
Freakin Scooters
I'm pretty sure Adam knows, and all of this posting is worthless.
Old 07-20-2010, 05:21 PM   #15 (permalink)
Shit, too many GD tranny numbers. All should use the same parts (minus internals). I was 1/2 asleep when I wrote it.
5 Lug Corolla WHAT?
