my 3VZ-FE in not behaving - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2010, 12:59 AM   #1 (permalink)
DJPsystems's Avatar
View DJPsystems's Photo Gallery
Question my 3VZ-FE in not behaving
I have an issue that I cannot figure out. The best way to describe it is a lack of low end torque/sluggish exeleration. When stopped completely I floor the gas it feels like a 4 cylinder intill it reaches about 3000 rpm, then the "power" kicks in and it pulls good all the way to redline. I also lost about 2 mpg. This started happening right after I had the transmission rebuilt. I have looked around the engine compartment and everything looks normal. It does not throw any codes. I have replaced:
ECM
air flow meter
plugs, wires, cap, and rotor
distributor
fuel pressure regulator
fuel filter
fuel pump
timing belt
O2 sensors
played around with timing
played around with air flow meter
fuel pressure is withing specs
tps is within specs
Car had around 150k, it now just turned over 200k. This is a 92 ES300. I do not want to throw any more parts at it and I would rather not take it to the dealership. If anybody has any ideas I would gladly appreciate it.
DJPsystems is offline   Reply With Quote
Old 07-20-2010, 10:24 AM   #2 (permalink)
View oldfirebird's Photo Gallery
Two guesses:
If it's an automatic transmission, put the gear selector in 2 and run it up to about 35 miles an hour. Can you feel the 1-2 shift? Maybe the transmission isn't shifting all the way down to first?
Or, the variable intake runners may be stuck on long runner? Is the actuator diaphragm torn, vacuum line cracked or disconnected? I honestly don't know how much of a difference that variable intake system makes....
oldfirebird is offline   Reply With Quote
Old 07-20-2010, 12:16 PM   #3 (permalink)
View camry6's Photo Gallery
Canada
ECM
air flow meter
distributor
fuel filter
fuel pump
timing belt
O2 sensors
tps is within specs
Also check the Throttle Valve cable adjustment for the transmission. Sounds like it's starting out in second or shifting to second too early.
camry6 is offline   Reply With Quote
Old 07-20-2010, 05:35 PM   #4 (permalink)
DJPsystems's Avatar
The trans is working normally. I can feel the shifts 1-overdrive and lockup. The throttle valve cable is set according to the repair manual, I even played with this adjustment but it does not help.
Old 07-20-2010, 06:07 PM   #5 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
Gameroom cash: $391902
iTrader Score: 6 reviews
View Gothmog3VZ's Photo Gallery
take off your intake manifold, clean out the acis system, see if that fixes it. Seafoam would also be a good idea
1993 Toyota Camry 3VZ 5-Speed
(Beige Beluga)
1989 Toyota MR2 3S-GTE 5-Speed (Din)
Need performance parts?
Shoot me a PM, I'll see what I can do
Gothmog3VZ is offline   Reply With Quote
Old 07-20-2010, 06:42 PM   #6 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
Sounds like a torque converter stall speed issue or fluid pressure issue.
Fully set the e-brake, also apply full pressure to the brake pedal, start the car, put it in drive, and floor the accelerator. Read the RPM quickly. Obviously, you'll want to be on an abandoned road or some other safe location.
The stall speed should be 2400rpm +/- 150rpm. If the engine turns higher or lower than that, take it back to the transmission shop and tell them the stall speed is incorrect.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 07-20-2010, 11:31 PM   #7 (permalink)
DJPsystems's Avatar
I have done the seafoam and cleaned the throttle body with carb cleaner but it did not help. As for the torque converter stall speed the tranny guy swore up and down that the torque converter was the proper one, he said the old one had some kind of color code and that is how they determined the application. Unfortunately he has since gone out of business. But even if it was the converter why would I lose about 2 mpg?
Old 07-20-2010, 11:48 PM   #8 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
If your statement about ithe cars power was "it was fine before" and then it had the trans rebuilt is correct, I'll say Jason nailed it 100%. Not all converters are alike and certainly not all torque converter rebuild shops are alike. Subtle change to the pitch of the stator/impeller inside the torque converter can change the stall speed. If your's dropped, it could give you the feeling of having less power as the engine is not in its powerband as it was before.
That's not to say it doesn't have other issues. We're just saying be advised that this could be roll and it could be changed but it'll require pulling the trans again.
FWIW; in the towing world its common practice to tailor the converter to the load by lowering the stall speed. Same is true of race cars raising the stall speed.
As ammunition, the ECM is programmed to lock the converter at specified car, gear, and engine speeds. Having the correct stall could play a role in how long the converter lasts (likely in a favorable direction this case), could be why it has a lower stall?
What fried in your trans and at how many miles?
73sport is offline   Reply With Quote
Old 07-21-2010, 01:07 AM   #9 (permalink)
DJPsystems's Avatar
I had about 150k when the trans "malfunctioned", the pump was whining and in D when taking off from a stop it would feel like it was in 2nd or 3rd. WHen put in 1st it would take off like it should. The rebuilder said one of the drums was bad, something about the splines where worn and also the pump was bad. Do you think that because of the lower stall speed it throws off something in the ecm programing and that is why it behaves like that?
Old 07-21-2010, 01:36 AM   #10 (permalink)
1MZ powered MR2
Yep, my 05 1GR Tacoma with the tow package has a stall speed of about 1800-2000rpm, but the engine really doesn't come alive until about 3000rpm. It doesn't feel like a 4 cylinder though, but it's also a 5 speed and not a 4 speed, so it has a very strong 1st gear to get the truck moving.
That's why I mentioned stall speed.
Yours could be a combination of reduced stall speed combined with reduced engine power from wear/tear. Those two combined could make it feel like a dog until it gets up to speed.
1991 Toyota MR2 V6
Old 07-21-2010, 04:44 AM   #11 (permalink)
The mechanic swears it's the right converter, but did you check the stall speed for yourself like Jason.MZW20 described?
The intake might be as clean as the day it left the factory, but if the actuator is bad or not being actuated, you'll still have a problem.
Old 07-21-2010, 06:00 AM   #12 (permalink)
OK, I just checked into the way the ACIS functions. There's to be NO vacuum at the actuator motor when idling or at low RPM. At high RPM the ECM opens the vacuum switching valve (vsv) the actuator actuates, and off you go.
If your vsv has failed or is getting bogus info from the ECM, you'll get vacuum at the actuator when idling.
Pull the vacuum hose from the actuator, cap the hose off, go for a drive. If you suddenly only have low end torque and the motor falls off at higher RPM, well then you need to do some more diagnostics on the vsv or the ecm.
Old 07-21-2010, 07:17 AM   #13 (permalink)
1MZ powered MR2
Well a malfunctioning ACIS system wouldn't be a drastic performance change. Most people wouldn't know the difference.
1991 Toyota MR2 V6
Old 07-21-2010, 09:30 AM   #14 (permalink)
engineer in training
Gameroom cash: $145055
The acis system wont affect low rpm torque like that, it closes in the upper rpm band to extend runner length.
I doubt this is a stall speed issue, though I cannot rule out bad converter yet. The 3vz makes almost full torque after 2000rpm, this sounds like a fueling issue.
Get one of those cheapo 02 sensor gauges and hook it to one of your sensors and look at what the sensor is reading when the bad behavior occurs. I bet it will read dead lean.
Old 07-21-2010, 06:19 PM   #15 (permalink)
DJPsystems's Avatar
Today I did the stall speed test and it went to about 2300 rpm. I also filled up the gas after doing mostly city driving, I calculated 17.2 mpg. As for the ACIS it did have a bad diaphragm but I had to buy the whole assembly because toyota would not sell me just the diaphragm. I was thinking I had a vacuum leak so I took some carb cleaner and sprayed it in different areas while the engine was running but I did not notice the engine rpm change. I feel like this car is possessed.
