Originally Posted by getyourgunn
Its a 1993 Camry LE with 220,000 miles on it but the engine and transmission have only around 180,000 miles. It hasn't been serviced since the engine and tranny was swapped out about 4 years ago. I was thinking of not doing a flush but a fluid change like in the diy section.
Thats probably the safest....but try to change out all the fluid. Its a good sign that the fluid didn't smell burned!
I think all these Toy trannys turn the fluid brown after some miles....mine was that way too. Mine probably had 40-60K on the fluid....
I've never seen any of my american cars do that! ...Except when their trannys start to go bad & slip,.. then it will darken up the fluid, but it will smell burned too!....
So I think that the "brown" yucky fluid look must have something to do with the type of clutch material Toyota uses & dosen't mean a whole lot!!!!
