1997 camry head onto 91 mr2 bottom end...both 5sfe? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2010, 01:13 AM   #1 (permalink)
View integra123's Photo Gallery
I want to know if the 91 mr2 5sfe bottom block will bolt right up with a 1997 5sfe head. From my short research, it should fit, but I want to confirm for sure. Thanks.
integra123 is offline   Reply With Quote
Old 07-21-2010, 03:45 PM   #2 (permalink)
anyone???
Old 07-31-2010, 05:07 PM   #3 (permalink)
View garyinpt's Photo Gallery
It should bolt up, however you will need to change the oil pump due to the crankshaft position sensor if this is going back in the 97. Also you may also need to tap two of the rear motor mount holes. I would also take out the balance shaft assembly and plug the oil hole...the thing is a waste. good luck
garyinpt is offline   Reply With Quote
Old 07-31-2010, 05:14 PM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
als make sure the water jacket holes line up right i believe the block needs to have the holes milled, or maybe thats only with the ge head ....
^ and leaving it that way!
Old 08-02-2010, 06:13 PM   #5 (permalink)
I'm trying to make this combo to work for my 1997 Camry. I have not mate the head to the bottom end yet, but so far I noticed the 97 block has a hole to mount the knock sensor. My 91 block does not have the knock sensor, so what do I have to do?
