POST 1 Attaching Hot Wire + Removing Interior Trim Gen 3.5
Hey Everyone. So I've finished everything on my install except for the actual mounting of the Amp, but it's sounding Fantabulous! Just need a little sub to round everything out and it's going to be like sitting in 1st row second balcony!
This is my first DIY write-up so hopefully it's clear enough.
Let's get started, this walkthrough will show you how to wire your car, as well as how to install aftermarket speakers in all 4 stock locations. Also, this is not the order that I did everything in as I had to do it in little sections. This entire install took me several nights chipping away at it a little bit at a time. Also for EVERYTHING that I did here I removed the - Ground on the battery to avoid potential damages.
First thing to do is to run the power cable to wherever you are planning on mounting the amplifier. I am putting my amp in the trunk.
1st you'll have to bypass the firewall, I did this by using an existing hole that was in my firewall b/c of a lazy ass installer put one there while putting in my car starter.
i cut his wire and drilled out the whole a little bit bigger so that my 4 gauge wire would go through, and then put in a rubber grommet.
Then I ran my wire, and my remote start wire through it.
The route that I ran my wire, I ran it behind the battery b/c I wanted to expose it to the elements as little as possible.
At the point where you want to put in your fuse you should follow the instructions of your install kit. Mine required me to cut the wire, install ends that would hold the fuse, and put this in a holder. PAIN IN THE ASS, but it'll work.
I tucked my fuse between the battery and the airbox.
Connect it to the POSITIVE side of your battery post.
and if your like me you want to hide it as much as possible so you can use wire covering and get the stock cover to fit over it.
Finally, I used a little bit of silicone to seal the hole that my wire went through.
WARNING. IF YOU LEAVE YOUR WIRE HOOKED UP TO THE POSITIVE TERMINAL AND THE OTHER END TOUCHES METAL WHILE YOU ARE RUNNING IT COULD GROUND AND CAUSE MANY SPARKS, BLOW YOUR FUSE, OR DO OTHER DAMAGE. I RECOMMEND DISCONNECTING BOTH TERMINALS ON YOUR BATTERY AND COVERING THE EXPOSED END OF YOUR + WIRE WHILE RUNNING IT!
NOW to the inside!
You will have a wire coming out from the footwell somewhere and now you get to run it back, but you've got to remove a bunch of panels first.
TO REMOVE INTERIOR PANELS AND SILLS
We'll jump around briefly to look at this. The key to pulling off panels is always pulling off as straight away from the mount as possible, so using your fingers and curling them tends to work well, u can also use needle nose pliers if it's accessible.
First start by removing the doorsill trim. It's easy, just gently unhook it at the back end, and then pull up gently all the way along. Keeping your fingers as close to the point where it's coming away as possible. Oh and the clip holding it to the front can be pretty nasty, just work at it and it'll come off slowly.
Once you've pulled it up and off it'll look like this.
The kick panel is held on by that bolt at the back, it's plastic so don't be to hard on it.
There are also two pop-mounts towards the front of the panel, it's the same on both sides.
After this you can remove the piller panel as well, it's held on by three pop-clips, and so as long as you start at the bottom corners you should be fine.
Sometimes the pop clips will slide out of the bracket on the panel as you can see in the above photo one clip is missing, just slide them back in after finding them, or removing them from where they stuck in the metal
Now we will remove the rear seat and side bolsters so that we can choose where to run the wires. There are two points on the front of the rear seat that you simply get a hand under and pull up on, you'll feel where the resistance is:
Lift up the front and the back will slide forward, put it aside for now. Now your back seat will look like this, except you might not have toilet paper or water...
At this point I'd flip down the rear seats and start taking off the side bolsters there is a bolt at the bottom of each that must be removed, then they simply slide UP and off:
The Rear sill piece is removed in t he same manner as the front. It runs all the way up the side and will probably have these clips in it up high.
with a small screwdriver or even a pen pop the middle IN:
Then Pry it out gently:
You can now remove the rear sill which will go all the way up. VIDEO
Around the interior of the pass through when your seats are down their is a rubber seal which you simply pull on to remove. The black pieces on either side will pop off from these 3 locations:
There are also 2 tiny philips head screw's in the middle behind the seat above where the rubber trim was those will have to be removed. This picture already has them out:
The C Pillar can be daunting b/c is has a bazillion pop clips, but these pictures will show you where they are so you can just get close to them and pop this entire piece off. It will not come completely off of course b/c the seatbelt runs through it. These pictures will give you an idea of where the clips are, and it's basically just a matter of popping them all out.
After that you can remove the high mount brake light, the plastic cover will come away separately and you remove it by pushing it slightly back towards the glass and then lifting. VIDEO
Once it pops up then pull up and away. Then two big bolts need to be removed, and take the electrical clip apart:
Now you can lift up your rear deck cover and slide it forward! You'll be left with this.
Now your ready to run wire!
