Gen4 Horn Connector - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2010, 06:38 PM   #1 (permalink)
Woo Hoo!!
sbushnak's Avatar
Gameroom cash: $173010
View sbushnak's Photo Gallery
4th Generation Gen4 Horn Connector
Good day all,
I have searched the forums and could not find the answer to my problem.
Today I was checking under the hood and the connector to the horn just behind the grill is loose. The wire got loose from the plastic connector and now I do not know how to connect it back in.
The connector seems fine but I need to insert the electrical wire back in. How can I do that?
I can take a few pictures and post them here if that would help.
Thanks in advance
1997 Toyota Camry LE I4
@ 193,000 miles
sbushnak is offline   Reply With Quote
Old 07-22-2010, 07:25 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Solder. I'd just run to a junk yard, cut off a good connector, and replace the broken one.
'07 Honda Ruckus Big Bore
Old 07-22-2010, 07:34 PM   #3 (permalink)
Woo Hoo!!
sbushnak's Avatar
Actually the connector is not broken at all. It looks fine.
There is small yellow clip on the outside of this connector. I took it out but still cannot figure out how to insert the wire in there.
Can I just take out the horn and try to connect the wire directly without the plastic connector as you mentioned?
@ 193,000 miles
Old 07-22-2010, 07:43 PM   #4 (permalink)
Freakin Scooters
I'm saying if the connect is damaged in anyway, you might as well replace it. Or just say screw it and hard wire it to the car and cut the connect out. New wire, solder everything up, heat shrink, done. If it's a matter of "how do i plug this in"... it's like anything. It's only going to snap together one way. Take a good look at things and try again.
If i'm COMPLETELY off here and not understanding.... pics?
The Following User Says Thank You to LynchburgCSI For This Useful Post:
sbushnak (07-22-2010)
Old 07-22-2010, 09:17 PM   #5 (permalink)
Woo Hoo!!
sbushnak's Avatar
Thanks. I'll just solder then and hope it holds it.
@ 193,000 miles
