97 Camry LE - Having squeak sound when steering Left or Right ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2010, 02:32 PM   #1 (permalink)
View Max7575's Photo Gallery
It is 150k k/m and What could be the problem? Thanks for inputs.
Max
Max7575 is offline   Reply With Quote
Old 07-23-2010, 02:52 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
like rubber squeak or your low on power steering fluid so the pump is screaming like a banshee squeak? also how is the tension on your ps belt?
^ and leaving it that way!
Old 07-23-2010, 03:06 PM   #3 (permalink)
Gameroom cash: $303255
^ Hi again Max. Like chronoti stated above, the most likely casue of this is a loose or worn power steering belt. First try tightening it. If that doean't help, replace the belt.
Mike
Mike Gerber is online now   Reply With Quote
Old 07-23-2010, 03:43 PM   #4 (permalink)
Hi chronoti and Mike nice to see you again and thanks for prompt reply.
I can't really tell what kind of sound it is but the tension of power steering is normal when driving. A friend said it was a strut bearing that worn out. I will follow your comments and see how it goes.
Max
Old 07-23-2010, 04:23 PM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
strut bearings make more of a clunking noise on our cars, i know what he is talking about, i had an old benz that squeaked like that
Old 07-23-2010, 04:35 PM   #6 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
It could be the rubber seal/grommet in the firewall, where the steering shaft goes from inside the car to the steering rack. A little silicone spray does the job.
71Corolla is online now   Reply With Quote
