Engine oil light came on then car lost power. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2010, 12:59 AM   #1 (permalink)
View Chipmunk's Photo Gallery
1998 Toyota Camry LE (4 cylinder) with about 180,000 miles
Driving at 35 mph. Engine oil light came on and engine started to lose power and RPM. Drove for about 200 feet then pulled over to side of road.
Checked dipstick and it was low on oil, so put in 2 quarts. After refilling, the oil in the dipstick was well above the full mark.
Tried numerous times to start engine but no luck. Battery is fine and so is starter.Starter motor turns over but engine won't start.
So is the engine kaput? Has it seized?
If the oil was dangerously low then should the light have come on earlier when the oil level was low but not dangerously low?
Thanks
Chipmunk is offline   Reply With Quote
Old 07-25-2010, 01:52 AM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Usually by the time the oil light comes on, you're screwed. Mine came on on night, I immediately filled it up with oil. Next morning the engine blew chunks.
Does the engine turn over?
Chris Crash is offline   Reply With Quote
Old 07-25-2010, 01:56 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
you prolly cooked a ring let the engine cool down and try again maybe jump the car so the starter gets more power to break the ring free
^ and leaving it that way!
Old 07-25-2010, 02:02 AM   #4 (permalink)
The starter turns over. I don't know how to tell if the engine turns over.
chronoti
Yeah I tried jump starting it too, no luck.
Old 07-25-2010, 02:04 AM   #5 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
Timing Belt?
Coincidence that the oil was low.
92 Corolla 4AFE, 94 Camry LE V6
91boz is offline   Reply With Quote
Old 07-25-2010, 02:07 AM   #6 (permalink)
Does it sound like it normally sounds when you start a car?
Or does it make funky noises?
Old 07-25-2010, 02:07 AM   #7 (permalink)
Originally Posted by 91boz View Post
Timing Belt?
Chris Crash
Sounds about the same.
Could the engine be flooded cuz the oil is about half an inch above the full mark on the dipstick.
Old 07-25-2010, 02:43 AM   #8 (permalink)
View djb2's Photo Gallery
How low on oil?
Is the tach jumping a bit when you crank the engine?
Avoid using the phrase "turned over". To some people, this means cranking with the starter. To others it means running on its own power, however briefly.
djb2 is offline   Reply With Quote
Old 07-25-2010, 03:15 PM   #9 (permalink)
Originally Posted by djb2 View Post
How low on oil?
Oh just a smidgen of oil on the dipstick, like 3mm.
Engine does not turn over, so tach stays at zero.
