Hey man i recently had bad cold start problems and even warm start problems sometimes. I went in and took the throttle body off and took the iac off the throttle body. The iac was pretty much clean (no blockage) because i sprayed deep creep in there the problem was that the deep creep took the factory lube off the valve and made it hard for it to open and close. All i did was take a thin layer of moly grease and carefully put it on top of the valve and opened and closed the valve manually until it was easy to open and close you can add a little more just make sure that the layer is thin and there's no mess i also cleaned the shit out of the throttle body and iac before i did that no problems since knock on wood hahaha. Someones gonna have to get in there if your gonna replace it why not try this first it takes probably an hour at most a little more if your gonna clean the shit out of everything like me
Yota Camry 2001 5S-FE 105,430 Miles+
