Originally Posted by sousame
I have a 99 camry 4 cyl. redoing the head gasket dont want to pull the block. what should i do to prep the block surface?
I think that Richie covered it, all you can do is clean the block deck surface.
The big question is....Why are you replacing the head gasket?????
If it is because it was leaking....Then you have to make sure the deck surface is flat & true. (This involves checking it with a machinist straight edge & some knowlege of how to use it)
If no leaking gasket...then just get it cleaned up & hopefully your good to go!
(The head is another matter....I would have it checked no matter why you pulled it off!!! Heads can warp just from removal, let alone other problems...so just get it checked)
To clean the deck surface...carefully scrape off all gasket & carbon with a flat tool WITHOUT damaging the block surface. (NO scratches!)
Then clean the surface with a solvent. I like the "brake cleaner" stuff,,,dries fast & no residue.
**** Try to make sure nothing drops inside the open engine!****
That's about it. Visualy check for any deck problems, make sure nothing is still stuck to the deck surface and it is clean & dry from any oil or other substance.....
...NOW...if you did have a warped or damaged block deck...then it's pull time & off to the machine shop to see if they can save it on the milling machine!
