Question....Please... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2010, 10:06 PM   #1 (permalink)
View 97ToyCar's Photo Gallery
On the gen 4's, how does the tachometer pick up engine RPM? 2.2 5SFE.
Sorry if it's a dumb question, I was just curious. Thanks!
97ToyCar is offline   Reply With Quote
Old 07-28-2010, 10:57 AM   #2 (permalink)
View Rattlin_Steele's Photo Gallery
Looking over the electrical wiring diagram & manual, it appears the instrument panel tachometer is driven by the ECU (ECU output terminal labled "TACH"). The ECU receives input from the "RPM signal circuit", which involves the Crankshaft postition sensor (ECU input terminal labeled "NE+") and the Camshaft position sensor (ECU input terminal labeled "G+") , although it looks like the Crank position sensor is the real driver for the RPMs. I assume the ECU then uses the input from the RPM signal circuit to drive the tach. The output from the ECU "TACH" terminal (Black/Orange wire) ultimately splits, with one leg going to the instrument panel tachometer and the other going to the A/C system's "A/C Amplifier".
Also, you really should've made your thread title more descriptive of the actual question. You'll likely get quicker and more responses.
Rattlin_Steele is offline   Reply With Quote
