What's the history on this car?
If you really want to make a day of it, pulling the intake plenum would be advisable. You can clean the ACIS, air intake plenum, TB, IAC, MAP (use only MAP cleaner).
Do seach for each of these. There are many DIY threads. The plenum is the hardest to clean due tp its size. Lacqure thinner seems to break down the deposits fairly well but its pretty flammable so be REAL careful.
Have you seen this:
http://camrystuff.com/index.php?page=Gen3_Manuals /
http://camrystuff.com/index.php?page=Gen4_Manuals
Pull up the EG2.PDF, (1MZ) and it will guide you through it.
An excellent time to replace plugs, fix leaking valve cover gaskets AND do a compression test too!
Edit, grab a new fuel filter and Air filter too!
