2000 camry ignition switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2010, 04:18 PM   #1 (permalink)
View artie in miami's Photo Gallery
My wife got stuck at work today...the key would go in, but not turn (steering wheel stayed locked etc) triple A sent a locksmith who tapped the key with a small hammer, gave it a spray of lube and said the ignition switch is on the way out. Would a newer key help to prevent this problem from happening...or should I just bite the bullet and replace the ignition switch. How tough a job is that ? Is there a site that explains how to do it ? thanks
artie in miami
artie in miami is offline   Reply With Quote
Old 07-28-2010, 11:56 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Was the steering wheel locked when she left the car? Sometimes it's tricky to get the key to turn when the steering wheel is locked. Try turning the wheel while turning the key.
'07 Honda Ruckus Big Bore
Old 08-31-2010, 10:16 PM   #3 (permalink)
View a17322a's Photo Gallery
OMG! Thank you so much for this information, my ignition cylinder stopped working after i changed my brakes..... The tap with hammer on the cylinder must have freed the tumblers or something but it worked again. Since you provided useful information and I went through the trouble of removing the ignition cylinder. First, take off the lower panel underneath the steering wheel, then take the small retangular panel around the ignition cyliner out (this small piece just pulls out) then put your key in and turn it to ACC (first click) then there is a small metal button that is recessed in underneath the ignition cylinder about 3'' in. Poke that button with something small and the whole ignition cylinder pulls out. Now, go to your dealer or wherever to get a new one with either a new key or keyed to your existing Key and replace same way with key in ACC and push it back in and install the panels back, thats it!
a17322a is offline   Reply With Quote
Old 09-01-2010, 01:52 AM   #4 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
http://www.tracystruesoaps.com/tutor...testarter.html
AliRazoR is offline   Reply With Quote
Old 09-01-2010, 08:02 AM   #5 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $324600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
I would try a fresh new cut key based off the key code. Don't trace your old one. The key and metal tabs inside the tumblers wear, usually the key will wear down so far that it becomes ineffective. If after using a fresh cut key off the key code doesn't work, then would I consider changing the lock cylinder.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
