Running rough hot code 31 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2010, 06:18 PM   #1 (permalink)
View eppoh's Photo Gallery
Helping a friend here. He bought a 95 Camry and put a used engine in it. The old one had broke a connecting rod. It ran okay for a few minutes, but then started running rough and died. Now it will not idle and runs only at about 1200 rpm with 3/4 throttle. The exhaust gets cherry red. It is throwing a code 31. I'm not a Toyota guy, so any help appreciated. ( Okay my wife drives an Avalon, but I never have to work on it)
2000 Avalon XLS, Bench seat, leather
227K
eppoh is offline   Reply With Quote
Old 07-30-2010, 07:05 AM   #2 (permalink)
bump for help pls
227K
Old 07-30-2010, 08:30 AM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Was the used engine known to be running properly before it was installed? My first thought is bad crank to camshaft timing. Bad ignition timing can also cause this, a clogged exhaust is another possibility, as well as vacuum leaks. Don't run the engine like that, the heat can burn up the combustion chamber very quickly, even burn holes in the pistons depending on what is wrong.
71Corolla is online now   Reply With Quote
Old 07-30-2010, 08:56 AM   #4 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
Code 31 refers to the MAP sensor circuit.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
